Posted By How on 28 Nov 2012 11:52 AM
1. Close the valves on the domestic hot water tank and shut off your desuperheater pump. If it continues to lose water, that is not it.
2. It is way simpler to use a non-pressurized flow center!
Regards,
Howard J. Ek, PE
You can have it with quality; You can have it fast; You can have it cheap. Pick any two.
Oh golly no!
In addition to what Joe warns about the danger of confining and then heating an incompressible fluid (water), please know two more key points:
1) The potable water loop through the unit's desuper has zero, zip, nada, nothing to do with the ground loop - different fluid, different heat exchanger, completely isolated.
2) The desuper pump is not positive displacement - water moves freely through it whether it is running or not.
