For what its worth. I too had trouble with my CM Tranq 27, the second year after a new install in 2008. It was FP1 fault if I remember correctly and after searching around (I believe I found the solution on this forum).... it turned out it was a somewhat known problem with a batch of thermistor sensors they were using for a period of time... would have been units manufactured some time before 2008 though... I put in the replacements ($20 each, ouch! didn't want to wait for warranty parts :)) and everything has been fine since then.
