Geothermal Heat Pumps
Tranquility 27 T1 and T2 Terminal Breakers
Last Post 18 Jun 2013 03:51 PM by
lomax0990
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
lomax0990
15 Jun 2013 06:27 PM
Hello,
I have a tranquility 27 that was installed about 6-8 months ago. I installed the system and was having some issues so to simplify things at the beginning I hardwired the pumps on the QT flow center directly to my panel.
Today I tried to wire the pumps into the T1 and T2 terminals so the flow center would only kick on with the compressor. But it seems the 7 amp breaker has been tripped. I tried to restet the breaker but didn't have much luck. Has anyone come across this or know how I can fix it?
Ryan
joe.ami
16 Jun 2013 09:53 AM
Are you talking about the low voltage breaker?
lomax0990
16 Jun 2013 12:32 PM
No it's not the low voltage breakers but the 7amp breaker for the T1 and T2 terminals. I'm almost 100% sure that's where I need to wire my QT flow center so it will only run when the compressor kicks on.
joe.ami
17 Jun 2013 11:22 AM
Hmmmm, well then you'd best check your wiring. Test for voltage across the terminals with wires disconnected.
pwagner3
17 Jun 2013 05:42 PM
I have the same setup and have had no problems, I will try to attach photos. I am only using one to the two pumps on my flow center.
pwagner3
17 Jun 2013 06:00 PM
On mine in the last post with photo's, the pump(220V) is wired to T1, both the white and black wires are hot.
lomax0990
Thanks for the reply. I will try that configuration when I get home this evening. I was trying to use the quick connect terminals (or whatever they are called).
Membership:
croccohvacusa
People Online:
