Bill NeuKranz, jonr, joe ami and geodude
Last Post 09 Sep 2013 11:19 PM by a0128958. 1 Replies.
AZ-gshp
| 09 Sep 2013 05:43 PM |
Bill NeuKranz, jonr, joe ami and geodude (if I left some off my apology)
I hope it is okay to use your User IDs in the title because I want you to see it. If not let me know how to remove it and I will.
First of all if someone would be so kind as to tell me how to mark my post as closed I will close this one and my original one.
Secondly, I am going to take Bill’s advise and ratchet back here, collect some more data and do my home work. In fact I have already visited http://www.welserver.com/ . There are several options of which I do not understand so I will call the company and see what configuration would solve the majority of my needs.
Third Thank You all for the help, insights and guidance.
I have attached two charts (should be read as one but I had to get it under 100kB) for you. (because I feel I need to defend myself a little and let everyone know it was never my intent to waste your valuable time) The charts are my actual electricity usage from my utility company showing the kWh for a 13 SEER A/C and then kWh for the GSHP.
You will have to go on good faith that our usage patterns have not changed one bit.
I have had a complete energy audit of our home completed, including vent leaks and blower door test etc. We have a HERS Index of 93. I was told this is very good.
The sq. ft. of conditioned space we are talking about is 2221
I really wrote this as a single post no reply required or expected, however expect to see me back when I have more data. |
Attachment: My_Usgae_#2.jpg
Attachment: My_Usgae_#3.jpg
Bill Neukranz
| 09 Sep 2013 11:19 PM |
You put me in good company, but, in fact, I'm a 'lightweight' particularly compared to the likes of Joe ami, geodean, Dana, docjenser and Engineer.
Your numbers show that you're paying about $50/month for cooling a 2200 sf structure with a tstat setting down at 70 degrees (6000 kWh / 5 months * 0.5 for rest of house * 10 cents).
If you had a 13 SEER A/C and you changed to a properly installed operating geo HP, and nothing else changed, or at least didn't degrade, then you should have seen dramatic savings at least on a percentage basis. I'd be all over this too if you're not seeing the savings.
If you're going to set up some monitoring, I'd be sure to collect CDD.
Bill |
185 |
185 |
