I currently have a project underway involving 17 geo package units serving 2
warehouse like structures. My question is, can anyone here point me to where I can learn about the efficiencies of step-down transformers that are used to supply the 208Y 3-phase power to the geo units?
These 2 warehouse structures house an
indoor sports business. Plenty of soccer, football and baseball fields, all with AstroTurf laid down.
The 2 structures are served by a closed water loop, of unknown pipe diameter, using a borehole field of unknown quantity of boreholes. Geo (package) units are evenly spaced around the fields, hung from the ceiling, each connected to the water loop. They are 208 VAC 3 phase, along with 2 water pumps configured in a push-pull fashion.
Electric service to the 2 structures is 480 VAC 3 phase. The geo package units were supposed to be 480 VAC 3 phase, but were incorrectly ordered and received as 208 VAC 3 phase, and, installed.
The building owner chose a solution of leaving the geo package units as is and instead changing the supply voltage at the circuit breaker boxes to 208 VAC 3 phase.
The building owner had on hand many
small 30 KVA 480 Delta to 208 Wye transformers, and installed these, versus installing one larger, appropriately sized transformer.
My question is, where could I go to research if there's efficiency gains to be had by removing the 6 small 30 KVA transformers and installing instead one much larger transformer.
The question being put to me is, how much am I (building owner) paying in utility cost for the inefficiencies of 6 small 30 KVA transformers, and, is there an economic case to be made for changing to one large transformer?
I know this is a different subject than usual here. But there are a lot of really smart people here, and, this still is a geo related subject. Any guidance or direction anyone can provide would be highly appreciated!
Many thanks!
