Venting Waste Valve: What is it?
Last Post 01 Jan 2014 09:15 PM by 6TonGeo. 12 Replies.
6TonGeoUser is Offline
28 Dec 2013 08:45 PM
I apologize if this question has already come up, but I am having difficulty searching the forum.
I recently had a geothermal system installed and have a buffer tank for the desuperheater.  The installation manual shows a "Vented waste valve or Vent Coupling" between the Tee on the supply line and the DSH In port.  What is this and were can I buy one?
29 Dec 2013 10:25 PM
Can you ask the company that installed the system?
30 Dec 2013 07:28 AM
Dunno the term. Can you attach the pic from the installation manual?
31 Dec 2013 07:17 AM
Thank you for the replies.  I've attached the diagram from the manual.
Attachment: Water_Furnace_Envision_DSH_Diagram.jpg
31 Dec 2013 07:18 AM
....forgot to upload.
31 Dec 2013 07:22 AM
take 3
geomeUser is Offline
31 Dec 2013 09:46 AM
Perhaps this is a bleeder valve to purge air from the lines.
31 Dec 2013 08:55 PM
Finally...WaterFurnace is recommending two tanks for DSH...YEA
31 Dec 2013 11:04 PM
Posted By geome on 31 Dec 2013 09:46 AM
That's what I first thought, so I bought a ball valve with a drain on it, but then I read this thread and got to wondering if I needed something like a T&P valve.
31 Dec 2013 11:09 PM
Posted By geodean on 31 Dec 2013 08:55 PM
They also show the non-buffer tank config and just have a note that the setup with buffer tank "maximizes hot water generator capability"
BergyUser is Offline
01 Jan 2014 09:53 AM
If you pipe the desuperheater as shown a vent is not needed. Piped as shown, you simply close the ball valve on the inlet and open a hot water tap somewhere. This forces ALL the water, and air,  through the desuperheater, back to the tank and out the tap.
Bill NeukranzUser is Offline
01 Jan 2014 12:10 PM
Bergy's diagram above is a classic, has appeared here hundreds of time, and should be in this forum's 'Hall of Fame' postings!
thank you all for the great replies.
People Online People Online: Visitors Visitors: 843 Members Members: 0 Total Total: 843
