Issues with Bosch Geo system
Last Post 08 Jul 2022 07:59 PM by crocodilejkg. 21 Replies.
barrenhillUser is Offline
14 Jan 2014 02:24 PM
very possible. Also possible I am not explaining it very well. Meeting with the Geo technician today to go over issues.
Re: duct work. It was all new ducting installed with 6" supplies coming off the main trunk into 2 zones. I think the trunks are 20x20. Ducts are 3x7 I think.
Zone 1 has is an open plan kitchen/living/dining area with 5 supply vents and 2 returns, 1 high and 1 in the baseboard. It is also feeding the basement laundry room and garage with 1 supply each.
Zone 2 is 2 Bedrooms with 1 supply each, 1 Bedroom with 2 supplies, 2 bathrooms with 1 supply each, Hallway with 1 supply, and basement with 2 supplies. Each bedroom has a return as well as the hallway has 2 returns
crocodilejkgUser is Offline
Hello everyone I am trying to diagnose an issue with my Bosch TA. We lost power Monday morning and when we got power back the Bosch TA was throwing a low pressure lockout. When I tried to restart the system the fan barley ran and one of the pumps to the ground loops had burned out. I replaced the pump without any issues and they both work fine. I suspect the fan motor is the issue, but I wanted to do some checking and verify that assumption. I have checked the signal voltages on the control board and they are all 24V along with the assorted green indicator LEDs. Power voltages for the motor are all correct where the high voltage plugs into the motor. I would like to verify the control voltages at he far end of the wire harness, but when I unplug the 16 pin harness from the motor the board stops the control signals and the green LEDs go dark. is this normal? I am assuming that the control board can detect when the harness id disconnected at either end and turns the motor functions off when it dose. I went ahead and ordered a new motor assuming the current one is bad and got a tecmate pro to try and test the old motor tonight. James
People Online People Online: Visitors Visitors: 199 Members Members: 0 Total Total: 199
