Posted By Baker on 27 Jan 2014 12:33 PM
... It's a standing well with a bleed off that dumps into a separate trench. I don't know how much water it dumps. What was described to me was more like a half a gallon a minute or so. I don't have any way to measure it....
If you are using 20 gpm for the heat pump and only bleeding off ~1/2 gpm, that means ~19.5 gpm of nearly ice cold water is dumping back into your well. No wonder the entering water temperature is dropping.
Is the end of the bleed pipe open above ground or below grade? I'm guessing it is below grade. If it was above ground or you had a place above ground where there is a joint in the pipe, you could put a one gallon container under the outflow and time how long it took to fill up to get an estimate of your bleed-off flow.
