Importance of type of grout (thermal conductivity) for vertical loops
Last Post 26 Aug 2014 03:27 AM by docjenser. 43 Replies.
Page 3 of 3 << < 123
waterpirateUser is Offline
24 Aug 2014 06:34 PM
Jonr,
We are fighting the same battle here. The point I am making is that all things in the software and reality are not equal. I am not a straw man, and you are not a looper. We are two people in this disscussion wit no skin in the game. Nothing replaces boots on the ground in a given area of operation. Nothing. If the added costs of TC grout make sense to this guy, then good on him.
Eric
25 Aug 2014 10:22 AM
"And your existing boreholes are 160ft/ton. So pretty much perfect (as far as these guesstimates go)."
There it is. Answer to the original concern.
The original question was about grout, but the concern was to make sure the installer did his job and whether or not to recommend them.
As I mentioned early on, it doesn't matter what you use, it simply matters that it is sized correctly. Fancy (expensive) grouts or loops may have applications, but in the context of residential geo, most times they will simply cost more with no return on your additional investment.
25 Aug 2014 06:59 PM
Posted By joe.ami on 25 Aug 2014 10:22 AM
Where is a " like " button when you really need it?
Eric
docjenserUser is Offline
Again, it depends.
If you are having a low conductivity formation,such as dry sand, the grouting material is not the limiting factor. If you are using 20' rods, and you are drilling through sandstone, this can go very easy and quick.
People Online People Online: Visitors Visitors: 187 Members Members: 0 Total Total: 187
