Need help fine tuning unit
Last Post 27 Nov 2015 09:01 PM by engineer. 5 Replies.
smalltimingitUser is Offline
24 Aug 2015 05:03 PM
I recently installed a 3 ton Miami Heat Pump. It is a closed loop with a GeoPulse flow center. It has been keeping the 2100 sqft house cool during our 110 heat index days. But it has not yet been fine tuned. Any suggestions on what to do? I have PT ports on suction and discharge. Help please.
docjenserUser is Offline
24 Aug 2015 08:33 PM
Se what your in and out temps are, and what the flow is. Calculate the heat rejection to the ground.
Check your air flow.
If you are within specs, there is not much you can or should do.
02 Sep 2015 10:43 AM
Thanks so much. I assume their are heat rejection charts online?
03 Sep 2015 09:40 AM
look for the manufactures installation manual. It should be online.
09 Nov 2015 09:00 PM
Posted By miguelkidwell on 09 Nov 2015 02:50 AM
Check your air flow from HVAC service tech guys, as if there is a problem then will replace it or undergo repairs according to the condition.
Is this a repose, or some kind of advertisement?
Link is to a contractor's website, so that would be an ad, not a response, demonstrating Mr. Kidwell's need to learn the rules around here
People Online People Online: Visitors Visitors: 354 Members Members: 0 Total Total: 354
