Geothermal 4" well need assistance
Last Post 01 May 2016 11:12 AM by jonr. 3 Replies.
islandsurferboyUser is Offline
30 Apr 2016 04:03 PM
I have a 4" well with a pump that get me 4 gpm. I'm adding a 4 ton geo heat pump system and need to pull the old pump out and put in a new one, thinking I need at lease 10-12 gpm to runt it and the house The well hits water a 40 feet but the well is 200 ft deep. What is the best energy efficient pump to use
30 Apr 2016 05:50 PM
You might want to check the wells yield before going too far. Ie, you are sure can it continually produce > 10 gpm?
Variable speed pumps are attractive. Always carefully check the flow and pressure curves (based on worse case level, not the total depth).
01 May 2016 09:07 AM
Thank you Sir - I will have my well guy check. If all is good - any suggestions on a pump?
You need the water level first. Ie, worse case (12 gpm + other usage (much much?), low water table), how deep is the water?
In the mean time, read this:
http://www.greenbuildingtalk.com/Forums/tabid/53/aff/13/aft/83335/afv/topic/Default.aspx
