Trane TVGX Intellizone2 using WF Aurora Weblink?
Last Post 17 Sep 2018 03:50 PM by sailawayrb. 1 Replies.
Bill CartUser is Offline
16 Sep 2018 04:26 PM
I'm new to forum and searched but did not find any information on this.
I just install a new 5ton Trane TVGX system with the intellizone 2 controls. From everything I have read my system should be compatible with the Aurora WebLink, but my dealer is not familiar with the Aurora Weblink being a Trane dealer. I have checked my system has the correct ABC rev2/AXB control boards and correct intellizone 2 stats for the Weblink. I just can't find anyone using a Trane TVGX system and the Aurora Weblink. Is there a branding issue since Water Furnace Aurora Weblink isn't Trane Branded? From everything I can find the Water Furnace 7 and the Trane TVGX are identical in every way. I really want the ability to see and have access to my unit online. Any help on this issue would be appreciated. Thanks
sailawayrbUser is Offline
AWL also requires one of the following thermostats be installed: TPCM32U03A, TPCM32U04A, TPCC32U01, or MasterStat. Lots of info here if you haven’t already read this:
AWL Installation Guide
You will most likely need to spend time working with AWL and Trane technical support teams before you will get a definitive answer and any possible solution.
People Online People Online: Visitors Visitors: 154 Members Members: 0 Total Total: 154
