Do I have to use a special thermostat with Water Furnace?
Last Post 30 Aug 2024 10:39 AM by newbostonconst. 1 Replies.
geonewbieUser is Offline
30 Aug 2024 02:34 AM
I'm asking for a friend who I will refer here, but I wanted to get the ball rolling.
They have a geothermal unit about 12 years old in a 2 story house. The upstairs thermostat has stopped registering the room temp. When they switch the 1st and 2nd floor stats, the upstairs will register the room temp using the stat from the first floor, but that upstairs stat will not work when it is put downstairs. They are pulling the front part off and switching them so they are not switching wires.  The stat is apparently the problem. They did change the batteries in it.
They purchased another brand (not specifically waterfurnace brand) that they said was the same type, but it did not work.
The waterfurnace brand is over $400 online from a dealer.
They have a service call set up for a $100 dispatch fee and I'm just trying to figure out if this is something they should be able to use a different brand stat on before the dealer sticks them with a bill for $500. Would any of the smart thermostats work such as Nest or Honeywell?
Could there be anything more sinister wrong than just a bad thermostat?
Any thoughts are appreciated.
newbostonconstUser is Offline
This is really not the right site for this, there are good HVAC forums out there...
I have changed from the factory therm to an ecobee on a climate master Geo and it worked but lost the variable speed function.
Is the water furnace a 2 speed unit or multi speed? Are the terminals at the units follow the standard....
https://www.acservicetech.com/thermostat-wiring
People Online People Online: Visitors Visitors: 125 Members Members: 0 Total Total: 125
