Posted By jensen06 on 02/26/2008 11:54 PM
We are installing our ledger today and had problems installing the screws. we predrilled the lvl tried driving in the bolts supplied by simpson but you cant suck the ledger in, once it grabs into the icfvl it spins out.
Did you predrill all the way through both the ledger & ICFVL? If so, are you sure you're using the correct size drill and not one too large, or too small? The hole in the connector needs to be just large enough to allow the screw to start but no so large that the screw doesn't cut metal. If its too small and you don't push the screw hard enough you'll just spin the screw tip on the metal.
