Solar hot H20 or PV panels
Last Post 26 Jul 2008 01:21 PM by egouin. 3 Replies.
AUSTENNNUser is Offline
20 Jul 2008 06:44 PM
I have SIP plans for a 3,800 sq ft home in Ruidoso NM with radiant floor hot water heating.  I have access to Nat gas at the property line.  Its south facing with a large passive solar concrete slab exposed to the sun in about 40% of the house.  How would one figure what would be the best investment; solar hot water heating for DHW and radiant or in PV cells  for the house?
20 Jul 2008 07:59 PM
Austennn,
You might want to post this under the Solar and Wind Forum.  Does your state have a net metering law to buy back the electricity from your PV panels?
BrockUser is Offline
21 Jul 2008 12:43 AM
solar hot water has about a 2.5 to 5 year payback, solar PV has between a 10 and 25 year payback.
egouinUser is Offline
Hands down, I'd recommend you go with solar thermal to heat your hot water.  PV is not nearly as efficient and much costlier.
Hope this helps.
Ed
http://www.GouinGreen.com<br>Superinsulated SIP/Modular House (HERS = 30)<br>GSHP w/SCW, ERV, Passive Solar, Solar HW
People Online People Online: Visitors Visitors: 344 Members Members: 0 Total Total: 344
