what's next best thing after SIP's and ICFs?
Last Post 21 Aug 2008 03:15 PM by wes. 2 Replies.
mf082008User is Offline
21 Aug 2008 10:44 AM
I'm new to the forum. Thanks to all here for my rapid learning curve, but I still have far to go.
I'm planning an addition in a hillside with a walk-out basement door, but 75% of the walls will be below grade. My house is in the mid-atlantic climate. From what I've seen here so far, ICF's and SIP's are the way to go, But I'm concernened that my site has too many trees, wires, and changes in grade to get a boom truck in. What is the next best thing?
The conventional method here is CMU with furred out interior finishes with insulation on the inside. Is it bad to take this approach?
Thanks for any advice-
Mike
21 Aug 2008 12:11 PM
Posted By mf082008 on 08/21/2008 10:44 AM
Well then, how are you going to get all of the CMU's to the site? If they can be delivered, either SIPS or ICF's should not be a problem.
JC is right, if you can get a load of CMUs into the site, ICFs would be easy. And concrete for the floor slab and the ICF walls come in the same trucks. A small tow behind pumper is more than adequate for basement walls, and takes up less space than the concrete trucks. Don't get talked out of doing it right.
People Online People Online: Visitors Visitors: 270 Members Members: 0 Total Total: 270
