roofing with an aerial lift
Last Post 03 Feb 2009 05:02 AM by greenfin. 4 Replies.
aksmith42User is Offline
15 Oct 2008 07:50 PM
i am getting close to being able to roof my new house and i was considering renting a jlg type lift for roofing it.  i've heard of them being used but have never seen it done.  i've roofed several houses and out of those a few off of roof jacks.  but i am hoping using a lift would be quicker than working off of jacks.  my house is a 9/12 pitch and will take about 45 square of shingles.  thanks for any opinions
adam
rkohlerUser is Offline
13 Nov 2008 09:14 AM
check out www.boeckeramericas.com they have lifts that are great for roofing and solar panel installations.
greentreeUser is Offline
15 Nov 2008 08:00 PM
Jack the bottom and walk the rest, maybe jack every 6-8' if you're having problems. I think a lift only works if its over 12/12. I use foam pads to keep shingles and place and to make roofing more comfortable, it also keeps you from sliding.
EboUser is Offline
12 Dec 2008 07:54 PM
Lifts of this type have a work platform that only really provides for reaching up. I would not suggest this type of lift for your roofing use, I think that you would end up trying to use it for carrying you and the shingles to the roof (they usually have only about a 500 pound limit) and then using the lift as a toe board (with you on the outside of the basket) Tie off and use roof jacks !
greenfinUser is Offline
I have no idea. But i want to share something with you. When the roofs are old and start leaking then you think to change the roofs but i want to tell you that there are many products in the market that helps you to prevent the leaking of your roof. EPDM, liquid roof, liquid rubber, liquid roof coatings. I think you need to go for these products.
<a href="http://www.epdmcoatings.com/">Liquid Rubber</a>
People Online People Online: Visitors Visitors: 311 Members Members: 0 Total Total: 311
