"Superior Walls" reversed
Last Post 14 Dec 2008 04:14 PM by Jelly. 24 Replies.
13 Dec 2008 06:15 PM
Maybe I am wrong, but I do not believe that thermal mass works very well in the deep South where the temperature does not vary very much.  However, if solar insolation is introduced to the home, then mass could be beneficial.
Kelly MooreUser is Offline
13 Dec 2008 09:51 PM
I am referring to the R-45 and how much can thermal mass mean to the efficency of the home than that...
Also if the home is built tight and has super insulation then why would you worry about the thermal mass???
Kelly
jmagillUser is Offline
14 Dec 2008 09:29 AM
Posted By Kelly Moore on 12/13/2008 9:51 PM
Kelly
The proper balance of interior thermal mass and insulation works in any climate.
Thermal mass  combined with the right use of night cooling a solar chimneys can reduce the need for air conditioning.
Who would not want to lower their electric bill?
14 Dec 2008 03:40 PM
Really, only if you were trying to incorporate some Solar into the mix. Otherwise, I wouldn't expect much of a payback.
Super Insulate, seal everything well, ventilate properly, and you've done way more than most, and you'll reap the benefits.
"It also insulates the house from the humidity and moisture that will collect on a concrete wall. If you are using a regular heating system, It will cost you more to charge the wall then you will re coop from it."
These things might be true if the concrete wall was not insulated externally.
People Online People Online: Visitors Visitors: 306 Members Members: 0 Total Total: 306
