The REAL DIY way of doing spray foam insulation
Last Post 15 Dec 2008 08:17 PM by engineer. 3 Replies.
TurkUser is Offline
12 Dec 2008 10:04 PM
OK, there has to be a more economical way to do this.
I have an older house with either no insulation or very old insulation in small amounts in a space or two.
I would like to spray foam (closed cell) the ENTIRE house where ever possible.
Now after getting some quotes by professionals to come to do the job and also looking at the DIY kits that come in what look to be basically propane drums I have come to the conclusion that neither is cost effective for as large a project as I have.
Hiring a contractor would be great if I just needed a room or two done.  The DIY kits are perfect for small projects or very small places.  But to do my entire home using either would cost a fortune.
There has to be a way to buy the same equipment the professions use but on a smaller less industrial scale to do the job myself.  That way I can just buy a large drum or so of foam and will have the equipment do the job myself for the entire house.
From what I can tell from searching the web the only two things you really need appear to be a paint sprayer machine (pump) and a proportioner machine that also heats the hose?
Can anyone help educate me to see if this is possible or chime in on what my options might be?  I have a hard time believing this is that difficult a thing to accomplish but rather just rare to do.
13 Dec 2008 07:49 PM
It sounds like a bad idea to me. From what I know about urethane foam....What if you apply to much in the cavity and blow out your drywall or siding. What if you apply too little. What if you leave a void.
Do what you do for a living, putting in a few more hours if you have to and hire professionals to do what they do. Especially if you have no experience and are asking us. I will hire a insulation contractor to insulate my own, next house.
I have seen customers, a veterinarian running a jack hammer on his project. A chiropractor framing interior walls. Just foolish if you ask me. What if they get hurt? "Just see an extra patient", I told them.
PolycoreUser is Offline
15 Dec 2008 10:53 AM
I would have to agree with ICF Construction, hire some one that has the equipment to do the job properly. Why would you want to purchase equipment if you are trying to limit your costs? I guarantee you that hiring a professional that has there own equipment will be cheaper than you trying to purchase the equipment and do it yourself. The other advantage to having a professional do the work is that they will have it done in no time at all. Time is money, and you will save both by hiring someone that has the equipment and knows what they are doing.
If the price point is still unaffordable than you may want to consider other alternatives to spray foam.
Polycore Canada Inc.<br>www.polycorecanada.com<br>1-877-765-9267
Very expensive to buy a spray rig. Much of cost is in the chemicals, anyway. Experience is needed to apply correctly, and the stuff is dangerous to breathe until cured.
Hire a pro.
People Online People Online: Visitors Visitors: 332 Members Members: 0 Total Total: 332
