We built out strawbale home with a post & beam structure. The wood we chose was white pine which was green and dried as the structure was raised and it was readily available (Ontario, Canada). There are many types of trees you can use, hardwood or softwood. All have different characteristics and some a easy to work with, others are harder. You need to determine whether the trees you have are the correct size and depending on the type, what their strength is related to sheer, compression, etc. If you look at the timerframe companies, you note they often build with: pine, oak, fir.
As for your questions:
- Green wood is easier to work with, e.g. cut, drill, etc., especially you are going to use a hardwood
- I would not worry about the moisture from the wood passing into the strawbales if you are plastering the inside
- It is difficult to get plaster behind the posts and you need to think about how you are going to do this unless you are 'embedding' the posts. We did not and it was not easy to get behind them when plastering
What type of trees do you have on your property?
Feel free to ask me whatever you want on the build process, what to look out for, etc.
