Rain Water Collection Sprinkler System
Last Post 06 Jan 2009 06:47 PM by aardvarcus. 3 Replies.
Cincy MarkUser is Offline
03 Jan 2009 07:50 PM
I have a basement sump pump which processes a significant amount of water.  My idea is to pump it into a storage tank, and then utilize this water to feed a sprinkler system.  I dont have a srpinkler system today.  Does anyone have any experience doing this?  Any thoughts / suggestions would be appreciated.
Mark
BruceUser is Offline
03 Jan 2009 08:36 PM
I considered it at one point.  That is until I did the math on the size of tank required for the yard.  In my case, the tank would have been very large and expensive.   Then there was the problem of where to put the huge tank.  It wasn't doable in my case.  Your case may be different.
Road BlockUser is Offline
05 Jan 2009 02:58 PM
You don't need a huge tank to hold the water. This system and others I've looked at use a small 50-100gal surge tank and water as water is availiable. This is one system I'm looking at http://www.rewater.com/ the only item you might consider a problem is it used underground emitters, sprinklers allow a lot of the water to evaporate before it gets to the roots. Since you have a lot of water to get rid of maybe you can just use their controller to manage your sprinklers.
aardvarcusUser is Offline
This would work best if you were able to pump this water uphill, and then be able to gravity feed it back down to a water hose or low pressure sprinkler system. Having to pump and then repump the water would seem to use quite a bit of electricity, but since you already have to pump it the first time to keep the basement dry, pumping uphill and gravity downhill will essentially not use a significant amount of extra electricity.
People Online People Online: Visitors Visitors: 338 Members Members: 0 Total Total: 338
