Heating help
Last Post 27 Jan 2009 10:40 PM by EastMark. 5 Replies.
EastMarkUser is Offline
23 Jan 2009 06:53 AM
Building a timberframe home in Mid-Maine...Walls R21 plus sheathed with 1/2 foil polyiso/Roof is SIPS R42. Should be pretty tight.
For cost cutting reasons Im contemplating going from propane tankless BBHW to a wall mounted direct vent propane monitor heater. I realize a single heat source vs baseboard throughout has a bit of a comfort drawback but the plan is extremely open on the layout. I have several ceiling fans planned.
These units run up to 55K BTU so thats plenty. I have one in my camp thats 35K BTU/theromstat controled and it works flawless.
I know install is a good 10K cheaper so Im really tempted. BTW,I have a woodstove that will be in the home also.
Im wondering the difference effeciency wise Id gain or lose ?? Any thoughts on one vs the other ? Different units you like ?
Thanks for your input.
Mark
25 Jan 2009 05:46 PM
Geez...nobody here using a monitor type direct vent unit ? Someone must know something.
Thanks in advance.
Mark
dennis-utahUser is Offline
26 Jan 2009 02:00 PM
I would check you propane costs carefully. You may be able to heat with electric baseboard units for less utility cost than propane, and at a lower installed cost too. This will depend on your local utility rates but where I live propane is more per Btu than electricity.
Dennis
27 Jan 2009 10:10 AM
Mark, you might have better luck posting on the radiant heating forum. They are the experts on btu's. Good luck
Jesse ThompsonUser is Offline
27 Jan 2009 10:56 AM
Here you go. Coldham & Hartman Architects in Western Mass have done extensive research in monitor heaters vs. central systems in low-energy houses.
Simple answer seems to be yes. Leave bedroom doors open, make sure you've got a ventilation method worked out (exhaust only vs. HRV depending on tightness / cost etc.)
We're doing a few houses like this now.
Link to ASHRAE paper including data from monitored buildings: http://coldhamandhartman.com/whitepaper.php?id=72
Jesse Thompson<br>Kaplan Thompson Architects<br>http://www.kaplanthompson.com/<br>Portland, ME<br><br>Beautiful, Sustainable, Attainable
Great find on that article. Thanks for all the input. Any of you folks 'looked at/experience with' different brands and effieciency levels ?
Im leaning much more toward the direct vent wall unot.
