Posted By aardvarcus on 01/23/2009 9:01 PM
In my next house, I will have a masonry wood burning fireplace in my living room. It will be near the middle of my house, far from an exterior wall. My only concern is how to properly insulate it as it pokes a hole through my attic insulation. It will have about ten feet of rise through my attic, so I was wondering how I could best insulate it. It will be directly exposed to the outside on top, so I need a way to slow the heat from flowing up and down.
I had considered making the chimney out of cinder blocks with a inner tile liner, and filling the first 8' worth of cinder block cavities with fiberglass, and then wrap the outside of the blocks with fiberglass. This might help some, but I will still have that direct masonry bridge from top to bottom. Any ideas?
Everything fine with your ideas. Maybe you can think about an bioalcohol fireplace. It needs no chimney and if used in ICF homes with high heat resistence it is a good extra for a quick heatup. Bioalcohol (96% Ethanol or better) burns with no toxic waste but should be of high quality. We have several users that are really happy with that solution. Attched a few pictures. If you goo with a complete chimney open fire place you should think about fire bricks and a glas version to not have a heatloss ( Thermal bridge) through your chimney.
