xps vs eps
Last Post 23 Feb 2009 11:27 AM by BadgerBoilerMN. 1 Replies.
thagreenUser is Offline
11 Feb 2009 12:11 PM
Hi all ,
Just came across some interesting data about xps and eps.
XPS is great  for density but not sure i'd use it myself for underlayment regarding concrete floors after reading this ! Check out the link.
www.foam-control.com/downloads/brochure/Foam-Control-EPS-Water-Absorporation-Facts.pdf
BadgerBoilerMNUser is Offline
Here in MN a vapor barrier (below the XPS) is required. You must also consider XPS below radiant floors drier by virtue of the radiant heat applied. In New Mexico, AZ and S. Texas not really an issue. As the article points out XPS is clearly hygroscopic.
When in doubt use Crete Heat.
See Don on this...
hehehee
People Online People Online: Visitors Visitors: 479 Members Members: 0 Total Total: 479
