Limited Funds - Two Options
Last Post 15 Mar 2009 10:30 AM by Naudi2u. 25 Replies.
02 Mar 2009 05:40 PM
The overhang is determined by the latitude of your jobsite, and the overall height of your windows.
Typically you want to shade your south facing windows from mid May thru mid August. The further north you live, the larger the overhang for the same height windows. (That seems wrong, doesn't it?) In my area (Kentucky) a 24" overhang is adequate for windows up to 72" tall. (This assumes the top of the window at 80", and an 8' wall height) Other wall heights and window heights will change the overhang depth. This all assumes a one story home. If your home is to be 2 story, then think porches.
John ClemUser is Offline
02 Mar 2009 06:06 PM
Here is a web site with some handy solar tools:
http://susdesign.com/tools.php
Home Design<br>
ICF Distributor<br>
http://www.clemdesign.com<br>
http://blog.clemdesign.com/
ConnellUser is Offline
12 Mar 2009 06:50 AM
I have always heard 3' as a standard rule.
12 Mar 2009 07:00 AM
The third economical option is to build with SIPs. There is a local manufacturer SIPs of America located in Blairs, VA.
Connell Rouse
SIPs Of America
want to buildUser is Offline
14 Mar 2009 01:50 AM
You can use google SketchUp. You can choose the geographic location and day of year and play with overhang length.
Naudi2uUser is Offline
Posted By bpwrightwv on 03/02/2009 2:46 PM
Posted By getwired on 02/19/2009 7:58 PM
Hello All,
I am planning on building a new home in Q3 of this year and would like to incorporate some green features. Ideally, I'd love to do Concrete masonry with a Geothermal HVAC unit, but the budget is not that big.  Therefore, I'm having to pick between the following two configurations:
1. 2x6 Wood Frame (xtra insulation and spray foam) with Earthlinked Geothermal HVAC.
2. Concrete Masonry Frame (ICF) with regular 13 seer heat pump.
I'm posting this because I'd like to hear others opinions. I'm currently leaning towards option 1 as I think that long term it will have a greater return, and the tax credits are much better now.  Any thoughts?
Thanks in advance!
[/quote]I don't know the cost diff between 2x4 and 2x6, if any, but you may be able to get by with 2x4 framing if you're using spray foam.  You should be able to get 3 inches of spray foam in the stud bays, giving you an effective rating of R-21.
I'm no expert-I'm sure someone here will have a better/more detailed opinion
Yes that can be done you can also add a product like dow's structural foam board instead of osb for a wall rated at r-26.5 with a thermal break and thickness of 4.5 in
Carlo<br><br>
People Online People Online: Visitors Visitors: 398 Members Members: 0 Total Total: 398
