EIFS Problems?
Last Post 27 May 2010 07:00 PM by EricAkkurt. 5 Replies.
djschrallUser is Offline
03 Mar 2009 09:26 PM
There have been many reports of mold/rot/moisture problems with EIFS systems in the past, and new products like DuPont Tyvek Drainwrap seem to have evolved specifically to help with the drainage requirement behind the rigid foam portion of these siding systems.
Can anyone give an informed response(not merely an opinion) based on experience/knowledge of that housewrap or equivalent, and its effectiveness in addressing that moisture issue. I have read a lot about this issue at buildingscience.com  .
I plan to use the aforementioned products on a house in Northeast Wyoming where the climate is quite dry(not humid)and only receives ~8-10" of rainfall per year, and would like to get some info regarding the likelyhood of encountering problems down the road.
Dave
04 Mar 2009 12:51 PM
Building scientist that I have talked to prefer one to two layers of roofing felt instead of synthetics such as Tyvek.  I have heard some of them say that the synthetics can compound the problem in wet humid areas.
greentreeUser is Offline
05 Mar 2009 06:42 AM
Joe Lstiburek did a test I found in JLC's Moisture Control book in which he says StuccoWrap with a bond break of felt OVER the stucco wrap produced the best system for drainage.
05 Mar 2009 09:49 PM
Posted By Alton on 03/04/2009 12:51 PM
Thanks for your input Alton, but...
I understand that these problems occur in wet, humid areas. That is not what my question was about, since the project is in a semi-arid, low humidity region...
So,... anybody out there with direct firsthand knowledge?
06 Mar 2009 06:02 AM
For real firsthand knowledge, get off your duff, go to nearest town, ask around until you determine the best EIFS installer in the area, then go ask him/her how they do it. That's the best way to get REAL FIRSTHAND KNOWLEDGE of how something is done in a specific geographical area.
This forum is made up of folks from all over the world, and I doubt that any of us have much experience outside of the areas in which we have lived and worked. And unless one of us happens to live in NW Wyoming, we will not have that direct knowledge you apparently are seeking.
EricAkkurtUser is Offline
EIFS   IS A GOOD SYSTEM BUT YOU MUST FOLLOW THE SPECS, IF YOUR LOOKING TO PUT EIFS ON YOUR HOME DONT GO WITH MECHANECLY SYSTEM GO WITH SYSTEM THAT HAS WEATHER RESISTING BERRIER, YOU CAN ALSO CHECK www.akrilon.ca for better idea.
People Online People Online: Visitors Visitors: 234 Members Members: 0 Total Total: 234
