airsource heatpump HOT WATER
Last Post 12 May 2009 08:47 PM by Jelly. 21 Replies.
07 Apr 2009 12:28 PM
Posted By Jelly on 04/07/2009 10:12 AM
Yeah, the AC is needed for the majority of the year in these parts. But there are about 4 months of the year on the other hand, when the heat pump would be on call for forced air heat. During those months would it make more sense to just switch the hot water heater tank back over to resistance? Or would letting the heat pump do double duty actually increase the efficiency?
Finding a pro to do the math is what I'm worried about.
Letting the heat pump do double duty for both space & water heating is the right thing to do- it increases the duty-cycle of the heat pump, which increases it's average operating efficiency as long as it isn't short-cycling.   Randomly timed 3 minute cycles would make it less efficient- 10 minutes + is better.  But as long as it's over 25F out, even short-cycling it may still be more efficient than heating your HW with resistance heating.  The short cycles would cause the seasonal operating efficiency of the heat pump top be much lower than it's steady-state operating efficiency, but overall you'd still use less electricity than if you went with all-resistance electric hot water heating.
Dana1, what if the hot water storage tank is about 50 feet away from the compressor? Would the set up with the air source heat pump and desuperheater still work for domestic hot water? I'm trying to figure out if placement makes a big difference.
People Online People Online: Visitors Visitors: 276 Members Members: 0 Total Total: 276
