What is it like living in a passive house?
Answers to frequently asked questions about the construction standard of the future
1) Can a house really stay warm without a heating system?
Passive houses that have been tested and are already occupied have conclusively proven: Even in our middle European climate, houses can be built with such low heating energy requirements that minimal additional heat added to incoming fresh air, is sufficient to keep the house warm and comfortable in winter. Measurements in passive home subdivisions have proven that energy requirements for heating can be accurately predicted, and that even with a great variety of occupants, calculated consumption agrees with average actual consumption.
2) Can you open windows in a passive house?
Of course, occupants may open windows whenever they want; however, they won't have to. A passive house is continuously supplied with fresh air via the ventilating system. This has advantages: Unlike window ventilation, fine filters in the ventilating system keep out dirt and pollen. Air quality within the house is always excellent, even when occupants are away and/or windows are never opened. Of course, as with all houses, if windows are left open in winter for longer periods, the inside air temperature will decrease noticeably, and energy consumption for heating will increase.
3) People often express reservations about the need for a ventilation system: Are there problems with bacteria, noise and drafts?
- The ventilation system in a passive house is a fresh air supply system, not an air conditioning system that recirculates inside air. Bacteria growth is only a problem in recirculating air systems (and then, only if poorly maintained). Fan and valve noises are almost completely eliminated by sound control measures (e.g., vibration isolation mounts, low air speed, acoustic lining in ducts). Jet nozzles guide incoming air along the ceiling from where it uniformly diffuses throughout the room at velocities that are barely perceptible.
4) Isn't a passive house a complicated, high-tech house?
- No, a passive house is very user-friendly and the equipment is easy to operate. The ventilation system has fewer controls than a normal television. Passive house technology is so simple, there's no need to hire someone to perform annual air filter changes; you can do it yourself.
The passive house technology
Main cause is the oxide emission from the burning of fossil fuels. 90% of the CO² emission caused in private household is produced from the central heating and water boiler. Make an appeal to a future home owner that he is also responsible for the environment, it is usually the case that he doesn't know what important contribution he can make to reduce pollution:
A one-family house with 1500sq ft heated living area, which barely meets the standards of the newest energy-saving-decree, can produce from the house heating system alone, an average emission of 2,7 tons carbon dioxide per year!
The goal of the passive house technology is, to reduce the active heating to a minimum "emergency" heating, which is only needed on a few days in the year. In the case of a one-family house this would mean a capacity of approx. 2 kW, about the amount of a small fan heater. Calculated, this would mean a usage of about 1,4kW per year, per sq ft heating living area. This consumption is also a given criteria for a passive house:
A passive house saves up to 80% heating energy compared to a building built to the latest energy savings.
