Blower Door Test relative to ASHRE 62.2
Last Post 14 Jun 2009 08:00 AM by jonr. 2 Replies.
fall50User is Offline
12 Jun 2009 11:44 AM
We have recently done a blower door test.  Our house is old 1940's bunglow and has multiple obstacles for air sealing.  Post blower door we tested @ 1500 cfm @ 50 Pascal's  which compared  to new construction standars is fairly leaky.  However for older house it's a step in the right direction
According to ASHRE 62.2 a house 1with 900 sqft house with 3 bedrooms needs bewteen 60 -75cfm of fresh air ventilation.
My question is:  relative to what my house tested for on the blower door (its getting a fair amount of infiltration because of its "leakiness")  In my case would fresh air ventilation even be neccessary via a product like an Fancycler or something similar
http://www.fancycler.com/need/default.htm
Bruce FreyUser is Offline
14 Jun 2009 02:19 AM
50 Pa is roughly 1lb/sf and is about the same as a 20 mph wind.  Depending on what experts you listen to (including ASHRAE), residential building should have between 0.5 and 1.0 air changes per hour or 20 cfm/occupant.
Hopefully the blower door test identified areas of improvement.  As it stands today, I don't think you  have a ventilation problem so I would rather spend the money to tighten up the house.
Fixing air leaks is usually a very cost effective way to save energy.
Bruce
Agreed. Tighten up the house and add wind blocks (trees?).
People Online People Online: Visitors Visitors: 249 Members Members: 0 Total Total: 249
