Canopy and JR in WV,
google: stabilization of road beds - some good info and links
try: contech-cpi.com and ACF Environmental
JR - even better method is to lay the material down and back the dump truck as it spreads the load evenly on the material - a good dump truck driver should be able to do that very easily!
There are materials called "geogrids" and "geo matts" used for stabilization of road beds. Typar and Tyvek are somewhat similar to the specialty matt fabrics. Grids and matts are used for different situations. They come in rolls.
I have used both extensively and I can tell you they do work! Saves alot of stone (it usually pays for itself with the amount of stone you save).
I do not know a supplier for Thailand but the manufacturers send these materials all over the world. You should be able to find it locally without too much trouble.
I just used matt on my new driveway in NC - the dump truck driver who brought my stone was really reluctant to do the backing/dumping method (he was afraid his truck would destroy the fabric). His truck has 4 rear axles! Twenty two tons of stone. You should have seen him smile when all went perfect!
BTW I was in Thailand in 1968 - beautiful!!! Road in a jeepny bus (highly decorated) thru the swamps/forest/country on dirt roads from Saatihip (I know that spelling is wrong but that is too far back to remember sp.) to Bankcok. Fantastic boat rides in the canals!
Best of luck in your build!
Rich
