ThermoDrain drain water heat recovery prelim performance
Last Post 25 Sep 2009 01:18 PM by EcoInnovation. 3 Replies.
EcoInnovationUser is Offline
25 Sep 2009 10:42 AM
As requested in a previous posting, here are the performance results for the ThermoDrain, a new and innovative residential drain water heat recovery system designed to lower costs and increase savings.
Here are the ThermoDrain drain water heat recovery performance numbers from our research and development lab.
These numbers are preliminary and have not been verified by a 3rd party.
Testing by a 3rd party is being commissioned and will be available in 6 months and will posted on our website.
Based on our preliminary test numbers posted below, the 40 inch length ThermoDrain has an efficiency of 50.9% at 9.5L/min in equal flow.
As of July 2009, the ThermoDrain is available through most plumbers and plumbing wholesalers and this is why we do not post pricing on the our website. Present MSRP for the ThermoDrain is $495 plus shipping and taxes.
Drain in (°C) Cold in (°C) Cold out (°C) Flow cold (gpm) Flow drain (gpm) dT cold    (C) Cold inlet (Lps) Flow cold (gpm)
Recovered Q (kW) dT drain (C) Drain flow (Lps) Drain Q (kW) Flow cold (gpm) Efficiency (%)
Recovered Q (kW)        30C dT
41.6 14.9 31.8 0.5 0.5 16.9 0.0315 0.5
2.22815093 27 0.0315 3.52021478 0.5 63.3%
2.50354037
40.5 14.4 31.2 1.0 1.0 16.8 0.063 1.0
4.4299332 26 0.063 6.88221765 1.0 64.4%
5.09187724
39.6 14.3 29.6 1.5 1.5 15.3 0.0945 1.5
6.05160518 25 0.0945 10.0069027 1.5 60.5%
7.17581641
39.6 12.7 27.3 2.0 2.0 14.6 0.126 2.0
7.6996458 27 0.126 14.1863337 2.0 54.3%
8.58696558
39.3 12.4 26.1 2.5 2.5 13.7 0.1575 2.5
9.03126263 27 0.1575 17.7329171 2.5 50.9%
10.0720401
40.1 12.2 25.6 3.0 3.0 13.4 0.189 3.0
10.6001973 28 0.189 22.0705601 3.0 48.0%
11.3980616
41.3 12.5 25.7 3.5 3.5 13.2 0.2205 3.5
12.1823163 29 0.2205 26.5795992 3.5 45.8%
12.6899128
Daniel Beauchemin
EcoInnovation Technologies
www.ecoinnovation.ca
25 Sep 2009 11:47 AM
9kw recovery @ 2gpm, that's ~30KBTU/hr- more than the burner output of many tank HW heaters, which isn't bad (except that it enables to take ridiculously long, even endless showers! :-) )
What are the drain & potable pipe connection diameters on this 40-incher?
And the pressure drop at 1.5, 2.5, & 3.5gpm flow is...?
If those numbers are confirmed in the third party testing it looks like it will compete head to head with (and handily beat the performance of) the slightly longer 4" x 42" PowerPipe, (which would indeed be set a new standard):
http://oee.nrcan.gc.ca/residential/personal/retrofit-homes/questions-answers.cfm#q45
25 Sep 2009 12:36 PM
This unit has 3 inch drain connectors and comes with 1/2" or 3/4" freshwater connectors.
The pressure drop at 9.5L/min  was 6 PSI.
Posted By Dana1 on 09/25/2009 11:47 AM
Actually, the Thermodrain is in direct competition with the Powerpipe 3" x 48" inch model $611 at home depot.
People Online People Online: Visitors Visitors: 333 Members Members: 0 Total Total: 333
