Building Science Article - Mold
Last Post 21 Feb 2011 03:18 AM by matteo. 8 Replies.
17 Nov 2009 04:44 PM
This recent article regarding mold ......by Joe Lstiburek is quite interesting
http://www.buildingscience.com/documents/insights/bsi-027-material-view-of-mold
richmUser is Offline
17 Nov 2009 07:06 PM
Just read it and a few other related articles. Sure makes metal skin panels look better and better! Now, just make them less $ and less $!
Rich
17 Nov 2009 07:52 PM
I was really supprised by the difference between the plywood and OSB
17 Nov 2009 08:46 PM
If anyone had asked, I would have voted for the OSB to be less likely to grow mold than the plywood.
That has been my personal experience. I would like to see the specifics of that test. Though I am not going to argue with Joe about the theory and validity of the test results.
I enjoy reading his articles. It hard to find a 'scientist' with that much common sense.
PolycoreUser is Offline
01 Dec 2009 03:45 PM
This article was a pleasure to read. This is a common argument from older contractors, that "houses don't breath anymore" and that "We are living in a germ infested plastic bag." I think the overall message is that we need to be conciously re-evaluating our construction practices as we introduce new material to ensure that the are being used appropriately.
On a side note, EPS has no nutritional value and does not support the growth of mold or mildew. Simply some food for thought.
Polycore Canada Inc.<br>www.polycorecanada.com<br>1-877-765-9267
AirMD Mold InspectorUser is Offline
02 Feb 2011 03:59 PM
You are correct. Over the last thirty years or so are house no longer breathe. If a toxin finds its way into your home, that's were it will likely stay. One of the primary culprits is mold. The last thing you want to do is to be breathing mold spores. If you have any doubts, I would recommend having a home mold inspection completed. Feel free to check out my site to learn more about indoor air pollution.
Brgds,
AirMD
RosalindaUser is Offline
04 Feb 2011 09:38 PM
But properly built tight houses DO breathe - but it is through a deliberate respiratory system, not through arbitrary leaks. Exactly how to design and build those breathing systems to be affordable, energy efficient and logical, is still in the development stage. I personally don't see ERV's and HRV's as the ultimate answer for every situation. I am sure more solutions will be forthcoming, and might even involve windows!
The article was written in a very amusing manner
-Rosalinda
FBBPUser is Offline
07 Feb 2011 06:50 PM
Posted By Polycore on 01 Dec 2009 03:45 PM
Don't that make ICF'S look good? Oops. not in the ICF forum anymore ;-) Having said that, this is not so much a "use to be wood" issue as the fact that people still don't understand ventilation. How many times on these forums hasn't someone said " I didn't run my HRV 'cause I don't have humidity? Maybe not but you still have got all those germs, toxin etc. Aim at at least 1/3 air exchange per hour for all occupied times. In cold climate (mid west and prairie provinces) hrv's are of dubious value if they are not sized at least a third larger than calc's would call for. They are in recir or defrost mode that much of the time when it is north of -20ºC
matteoUser is Offline
I have mold problems at home, too. They are on the floors even when the floor is dry and sometimes inside my drawers. I have read an article and that one of the reasons of having mold problems at home is by storing materials such as paper, books, clothes or other possible sources of food for mold in humid parts of your home which I think why there are molds inside my old drawers.
<a href="http://www.buildingmaterials.co.uk/Plasterboard.html">Plasterboards</a> | <a href="http://www.buildingmaterials.co.uk/Plaster-Walls.html">Plaster Walls</a>
People Online People Online: Visitors Visitors: 382 Members Members: 0 Total Total: 382
