Posted By popawheelie on 22 Mar 2010 04:06 PM
I'm new here and am not very informed on insulating and weatherizing homes.
I have a small wall 8'X20' that I want to re-side and install two new windows in.
I want to keep the drywall intact on the inside.
I'm in No Colorado so it does get cold.
Material cost isn't a big issue because the wall is small.
Is there step by step info on detailing this?
I would like to have a foam board or panels on the outside of the studs.
So far I'm thinking of this.
1. Since I'm not taking the drywall off I should put a vapor retarder in the wall bays first. I could us paper faced R-11 with the paper on the interior side. this would slow down the migration of interior moisture to the outside.
The R-11 warms the bay a bit so the temp differencial is moderated somewhat.
2. then I could cut unfaced open cell foam in the bays and foamed in around the sides. I could set the cut foam in a little in from the outside edge of studs so there is a bit of an airspace.
3. I'm not sure if I need sheathing on this wall. I'll see what is on the wall when I open it up.
4. On top of the sheathing or studs I will put an open faced foam. I'm not sure how thick at this point.
5. Nailing strips or a rain screed goes on next.
6. Then a vapor retarder/barrier/house wrap goes on.
Does this sound right? Let the corrections begin!
The more foam you put on the outside of the studs, the less relevant interior side vapor retarders become. Unless you're already committed to pulling the exterior sheathing off, you can probably save labor and get more water protection by dense-packing cellulose into the cavities from the exterior before putting the foam board up.
If you ARE committed to pulling the sheathing, caulk all seams where wallboard & framing meet, and foam seal around all plumbing & electrical penetrations, then spray on vapor-retardent latex paints (that are semi-impermeable minimum class-II vapor retarders, but still allow SOME inward drying.). Then, wet-spraying cellulose from the outside will fill all voids & imperfections far better than any batt-job, and will block 95%+ of intra-insulation convection that robs batts of R-value when the temperature differences are high (ie. when you need it most!)
But if you insist on batts, unfaced high-denstiy "cathedral ceiling" batts have lower convection and will give you ~R15 in a 2x4 studwall, and the extra performance is well worth the slight increase in cost. If you have an micro-cavities narrower than 1" that aren't readily stuffable with insulation, fill them with 1-part foam (Great Stuff, etc.), and trim the excess flush after it's set up.
Foam board isn't very structural- if you don't use OSB or plywood sheathing you'll need angle-bracing planking to stabilize the wall from racking under wind loading.
Unless you're putting up at least R20 of foam on the outside it's better to use unfaced foam so that there is decent outward-drying capacity. But 3" of foil-faced isocyanurate runs ~R20, and may be the worth it. FSK tape (2" aluminum, designed for this purpose) makes it a near perfect air & vapor barrier. Foam seal the tops, edges & seams to make it completed. With R20 on the outside of a 16" oc. batt or cellulose insulated studwall the average winter temperature of the coldest side of the stud will still be above the dewpoint of the 30-35% relative-humidity 68-70F interior air, and condensation/mold conditions are fleeting- a few hours on the coldest days of the year at worst. But if you go thinner on the exterior foam it needs to be unfaced so that it's more vapor-permeable than the interior side vapor retarders, and dries toward the exterior. At 2" of thickness XPS (pink or blue rigid foam) is only R10, and has a vapor retardency of about 1 perm- similar to the interior side vapor retarders, and that's about the max you should go unless you design the stackup & R values specifically for inward-drying. If your plan was to put 1/2-1.5" unfaced foam out there, go for it.
Assuming it's less than 2" of XPS, do NOT use vapor retarders on the exterior, only air-barriers (like housewrap or classic felt products, both of which are vapor-permeable). But any wraps should be next to the foam, not the siding, if you're using furring to form a rainscreen gap behind the siding (which is an excellent plan, BTW.)
