I just received my estimate to apply spray foam to the attic, gables and knee walls in my existing home. We live in eastern central Florida. The estimate was for Demilec Sealection 500 (1/2 pound). I have the option of applying sufficient thickness to make R-19 which I from my calculations is about 5" or R-30 which is about 7.9 ". The prices for each look reasonable as they are much lower than another estimate I received for the same product. I am concerned that while the current code says R-30 for ceiling insulation (the old requirement was R-19), R-19 will provide me with about 93.4% efficiency, the additional 2.9" of foam to reach R-30 will only increase the efficiency by 2-2.5%. For an increase of 33% in installation costs, it may take a long time to recoup that 33%. The existing fiberglass batts are loose, fallen fallen down and are generally not functional from years of additions and modifications so anything should be a significant improvement. Any thoughts are appreciated.
