ERV and HVAC integration question
Last Post 08 Jun 2010 07:41 AM by cmkavala. 5 Replies.
rburdittUser is Offline
04 Jun 2010 06:34 PM
i have seen lots of examples where an ERV is integrated with hvac unit by piping return air thru it and adding the fresh air back to the return downstream from where you are exhausting.  my question is what controller(s) will integrate the two pieces of equipment so that the ERV can energize the hvac fan and when necessary?
the only controllers i have seen do not integrate the two.
thanks for any help!
05 Jun 2010 06:44 AM
rburditt;
I have not seen any that integrate them for residential use, they are made for commercial use by Johnson  , but not affordable for home use
ERVs can work off a direct switch, percentage timer or humidity sensor
05 Jun 2010 10:21 AM
if they are not integrated then is it ok to run when the hvac is not running?  i even thought about the honeywell controller that controls a damper for make up air...i wondered if it could be used to energize the ERV instead of the motorized damper it is intended for??
05 Jun 2010 10:38 AM
Posted By rburditt
yes , that is the recommended "best" application
sastexanUser is Offline
07 Jun 2010 11:23 PM
I know my Carrier Infinity controller is capable of controlling not only the HVAC and humidifier, but also an ERV/HRV if I want to add it in the future.
Posted By sastexan on 07 Jun 2010 11:23 PM
I read up on that controller and it will work provided ducts are properly sized, if ducts are undersized or oversized it will give false readings to the controller
People Online People Online: Visitors Visitors: 434 Members Members: 0 Total Total: 434
