Polyiso adhesives and question on installation
Last Post 07 Sep 2010 09:46 AM by Dana1. 5 Replies.
simonzekeUser is Offline
23 Aug 2010 03:54 PM
Hi everyone,
       Somewhat new to the forums and learning a lot!  I am about to start insulating the interior of my basement in a 1956 house in Nebraska.  I have two questions.  What is a good adhesive to use to glue unfaced polyiso to a concrete block foundation wall and should I use the same adhesive to glue two panels together (is there a spray adhesive to get better thermal connection between panels)?  Where do you buy these products?  I have 1 1/4" panels and will have two layers.  I have heard some adhesives will eat away polyiso.  Also, at the floor of the basement, I have old tiles glued to the concrete floor that have asbestos in them so I am not going to disturb them.  My question is if I leave a narrow gap at the floor (maybe a half inch or so and fill that in with sprayfoam to get a better air seal, will that be better than having the panels directly on the floor?  I am going to be taping seams and staggering the seams of the second layer to minimize thermal bridging.  The foam board will be covered by a traditional non-load-bearing stud wall with little or no insulation in the wall cavity - just drywall to finish the wall and meet fire regulations.  So, I guess that is 4 questions but thanks for your input!
Simon
24 Aug 2010 03:17 PM
Posted By simonzeke on 23 Aug 2010 03:54 PM
Hi everyone,
Simon
I'm assuming you mean fiber-faced, not UNfaced iso(?).
Only use foam-board construction adhesive- others are likely to have solvents that degrade/dissolve the foam.  Walnut-sized blobs on a ~18" grid are sufficient to get it to stick.  You can either try to glue the butted up sides with the adhesive, or leave a ~1/4" gap between them to be sealed with single-part foam (Great Stuff, or similar) and skip the taping- just plane the excess flush before applying the second layer.  Stagger the 2 layers by at least a foot, and use smaller blobs of adhesive to minimize the air gap between the layers.  (Foam board construction adhesive is available at the big blue & orange box-stores.)
You can either hold it permanently in place in a fire-code compliant manner with furring through-screwed in to the concrete on which to mount the code-required ignition barrer, or lock it in place with your studwall.  2.5" of iso is ~R15- adding un-faced batts to the studwall may still be worthwhile if you go that route vs. furring.  A 2x3 studwall & unfaced R8 batting would bring you to over R20 at low cost with minimal intrusion into floor area.  Even kraft facers are too vapor-impermable to be used here.  If unfaced R8 isn't available, the cheap unrated batting used for sound control in 2x4 partition walls would still deliver ~R8 when compressed into a 2x3 cavity (~R11-ish in a 2x4 studwall.)
Before gluing anything up though, seal the foundation with a silane or acrylic masonry sealer to minimize the capillary draw of ground or rain-moisture through the concrete into the interior. This will enhance the bond of the adhesive.  Use only vapor permeable sealers though- nothing with a perm rating less than 2. (Most are quite permeable, but a few aren't.)
DO leave a gap between the iso and the floor.  Bare iso is somewhat hygroscopic and it CAN wick up water. Filling the gap with one-part polyurethane foam (which ISN'T hygroscopic) gives it a capillary break. (Use a sill gasket under the bottom plate of the studwall too, for good measure.)
If you're going to paint the wallboard, stick with vapor-permeable latex/acrylic. The foundation needs to dry toward the interior, otherwise the moisture level in the concrete can get high enough to cause efflorescence/spalling conditions on the exterior above grade and/or cause the foundation sill for the first floor framing to rot, as well as create mold & rot conditions in your basement studwall.
26 Aug 2010 11:16 AM
Thanks Dana,
         I have foil-faced poly iso and I have been peeling away the foil layer of my sheets so I do not have an interior vapor barrier.  Needless to say this has been a tedious task but I did not want to waste the recycled foamboard that I purchased last year (75 4x8 sheets for $600).  I am almost done now and ready to begin installation as I said.  Now both sides of the foamboard are unfaced.
         About the silane or acrylic masonry sealer, the concrete block walls have 2 or 3 layers of latex paint on them.  I presume that will need to be removed for the sealer to work properly?   Thanks again for all the tips!
Simon
26 Aug 2010 01:48 PM
If the latex isn't bubbling & peeling, it's probably good to go as-is, no sealer required. If there are only localized spots where the paint is failing, hitting it with a wire brush on a drill motor/grinder to knock off the loosest bits and spot-sealing it would probably do it.
greencleaningUser is Offline
07 Sep 2010 09:20 AM
PolyIsocyanurate insulation is a type of insulated foam board that offers a high level of thermal resistance and cold weather protection for your home. Polyisocyanurate insulation costs more than other types of foam board but can help to save you thousands of dollars in electrical heating and cooling costs. Installing and using polyisocyanurate insulation is not that difficult; however, there are a few things you should do during the installation to make the insulation more effective. This simple how-to guide will provide you with some steps you can use to make installing polyisocyanurate insulation in your home easier and more energy efficient.
What You will Need
* Polyisocyanurate insulation
* Vapor barrier
* Drywall
* Plywood sheeting
* 2x2 or 2x4 framing studs
* Utility knife
* Concrete adhesive
* Measuring tape
Here's to you, your health and the health of your family. <a href="http://www.cleaningcleaner.com">Eco friendly cleaning</a>
Posted By greencleaning on 07 Sep 2010 09:20 AM
What You will Need
* Vapor barrier
* Drywall
* Plywood sheeting
* Utility knife
* Concrete adhesive
* Measuring tape
Under no circumstances should you put a vapor barrier on the interior of a foundation wall in a sub-10,000 heating-degree-day climate, otherwise ground moisture will have nowhere to go but up via capillary action.   This creates spalling & efflorescence issues on the exterior of the above grade portion of the foundation, and a high potential for damaging levels of moisture in the foundation sill & band joist.
People Online People Online: Visitors Visitors: 192 Members Members: 0 Total Total: 192
