Lines on finshed rock dash stucco
Last Post 06 Sep 2010 07:11 AM by cmkavala. 3 Replies.
jtopsUser is Offline
05 Sep 2010 07:42 PM
Hi
I am concerned about lines appearing on my stucco when it is wet.
The lines disappear when the stucco dries ( no cracks appear yet)
Could some one tell me if I should be concerned about these marks.
The stucco was completed about a month ago.
I will attach a picture.
Thank you in advance
Vancouver, Canada
05 Sep 2010 08:10 PM
those lines are the cracks
05 Sep 2010 09:42 PM
Thanks for the info but when the lines
dry you can not see any cracks on the surface?
Are you saying that there are cracks below the surface.
What should I do about these lines.
Should I be concerned.
jtops;
All cement stucco cracks, the cracks are hairline, I don't know how old your stucco is or if it has ever been sealed. It should be sealed every couple years with a clear sealer, I like thompson's , that can be applied easily in a pump sprayer.
stucco is pourous and will be penetrated by water, in a cold climate I would be afraid of the freeze - thaw cylce expanding the stucco from behind under the right conditions
People Online People Online: Visitors Visitors: 395 Members Members: 0 Total Total: 395
