Thermal Break strip in doors and windows
Last Post 11 Oct 2010 05:39 AM by Chris Dawson. 0 Replies.
Chris DawsonUser is Offline
Thermal break could be described as basically the addition of a thermal insulating material between two thermally conductive materials e.g. element of low conductance placed between elements of higher conductance to reduce the flow of heat, often used in aluminum windows. It prevents or reduces the direct transmission of heat or cold between two surfaces.
Thermal Break Polyurethane - improving the thermal performance of glazing systems is important for energy conservation in buildings. A low conductivity polyurethane resin in an extrusion cavity is sometimes used. When hardened the base of the cavity is sawn giving a composite extrusion which is a single structure. Thus, the thermal bridge which separates the frame's interior and exterior has better energy conservation properties and will reduce condensation or frost.
Thermal break can use the pouring and de-bridging method, or rolled thermal break technology. This means joining of two parent aluminium extrusions by the mechanical insertion of extruded polyamide strips. This makes a single thermally broken assembly, giving greater thermal and energy efficiency and it's environmentally friendly.
It will bring you a comfortable life and a good mood everyday!
Any question please feel free to contact me any time!
Regards
Chris
Email:[email protected]
MSN:[email protected]
Skype:whsunrise
Membership Membership: Latest New User Latest: IntegratedHomes New Today New Today: 0 New Yesterday New Yesterday: 1 User Count Overall: 35026
People Online People Online: Visitors Visitors: 209 Members Members: 0 Total Total: 209
