HRV basics - questions
Last Post 14 Dec 2010 10:07 AM by NelsonL. 3 Replies.
woksawiUser is Offline
07 Dec 2010 07:28 PM
We're going to be installing an HRV in our new construction.  Because we have radiant flooring, it will need it's own designated ducting on two floors.
Some questions:
- is it a bad idea to have the HRV vents in the floors of some rooms (e.g. coming up from the bottom floor) rather than running ducts through the attic (in addition to the ducts that will run across bottom floor/basement ceiling)?
- have read conflicting info that supply/return should be in same room and also that it should NOT be in same room.  If no forced air system, which is it?
- have also read conflicting info re intake/exhaust.  Some say it's ok to put close to one another.  Common sense tells me that it wouldn't make sense (why pull in air you've just exhausted?)
- if the intake if far from the unit, does that affect performance?
- suggestions on good HRVs?
FBBPUser is Offline
11 Dec 2010 11:12 AM
where are you located?
adi43dUser is Offline
13 Dec 2010 01:19 PM
have a look at venmar eko - hrv and erv - and regarding the install I'd go by their recommandations
adi
http://torontonetzerohouse.blogspot.com/
NelsonLUser is Offline
The Ultimate Air unit is also very efficient (both the motors and heat exchanger).
Check out efficiency numbers of HRV/ERV untis at http://www.hvi.org/resourcelibrary/proddirectory.html
