WaterFurnace NDV049 question
Last Post 06 Mar 2011 07:02 PM by grewen. 2 Replies.
Geouser
| 26 Jan 2011 09:09 PM |
I had an NDV049A111CTR installed 3 weeks ago that replaced an old FHP (3.5 ton I think) that shot craps after 8 years. Not sure what model it was though. The original loop and ductwork remained the same except for some modification to the return air duct at the furnace. The thermostat was replaced with a programmable WaterFurnace stat. I have a water heater and storage tank that were also reused and hooked up to the new furnace using new copper pipes. I have a couple questions regarding this new unit.
1. The furnace will run 35 to 40 minutes every hour even though the outside temperature is in the mid teens. It is in 1st stage almost all the time so I am wondering if this is possibly just normal operation? The FHP never seemed to run this much.
2. The unit is located in the basement and makes an annoying hum/vibration that can be heard easily throughout the house upstairs. It is much less noticable near the unit. The noise is also much more prominent in the 1st stage of operation. If running in 2nd stage it is a lot quieter. Is this normal?
I had the installer, whom I have been pleased with, return to check the unit and they say all is fine and operating properly. The technicians work order did not list the temperatures but noted the following - Temperature drop in loop 9 degrees. Check airflow, temp rise at coil 29 degrees. Checked desuperheater operation.Checked unit amp draw. Check blower speeds. Unit working ok.
I am still concerned however with the run time and annoying noise or vibration. Any insight or suggestions would be much appreciated.
Thanks, Ashoop <!-- / message --> |
WF_Inc.
| 27 Jan 2011 01:56 PM |
Geouser,
It is common to see longer run times with extreme weather conditions. Could you provide the model number of your thermostat so that we may look into your inquiry further?
Unfortunately, noise is very difficult to resolve over the internet. If your contractor is unable to resolve the noise issue, please have them contact our technical support staff to discuss the nature of the noise. They will be able to offer suggestions and work with your contractor to find a resolution.
WaterFurnace International, Inc. |
grewen
| 06 Mar 2011 07:02 PM |
we have the same furnace, and by the sound of it we also had the same annoying hum. after lengthy time spent in the crawl space, i found the hum coming from the 2nd circulation pump. the installer had mounted it on a pony wall and that sent the hum through the whole house.all i had to do was loosen the pump and place a small rubber blanket behind the pump to insulate it from the wood |
252 |
252 |
