Earthship/Tire home in Maryland?
Last Post 25 Jun 2015 04:45 PM by toddm. 55 Replies.
cmkavala
| 14 Feb 2011 07:41 AM |
We all have different opinions of the perfect home, living and building green does not require one to be a cave dweller |
zehboss
| 14 Feb 2011 07:57 AM |
No home should be cave like. Good zero energy design has high natural lighting, properly placed window, and no disadvantages. Only bennefits of smart design. |
ICF Solutions Engineering, Designing, and Building Passive, Net Zero, Self-Heated, Self-Cooled, Self-Electrified, Low Cost Homes Basic shell starting at R-50 Walls, R-80 Roof structures. for $30/square foot (360) 529-9339 [email protected] |
renangle
| 14 Feb 2011 08:51 AM |
Beastmaster, As someone who lives in the State below you, I don't like straw bale because of our humidity and that it could become a problem. You can take measures to reduce those chances. If you were in Arizona, or a much dryer State I would keep quiet. Also, the thing that I always come back to when I think of an earthship house made out of tires, is the potential impact you will incur should you one day wish to sell it (not that you are ever going to sell). You would need to find the ideal buyer for the place should it ever go for sale or suffer the consequences. Granted it may not cost much to make and you could pass the place on the relatives for the next 100 years, but it is something that I do think about. I would consider more mainstream green construction methods, but like everyone it is simply an opinion. Best of luck with whatever you chose to do. Ren |
Rosalinda
| 14 Feb 2011 10:46 AM |
Just do a lot of reading and research and thinking before you start to build. Make sure you have every detail figured out. Consult with folks who have done what you want to do and maybe even apprentice on one of their projects to learn the skills, Definitely work with your local code folks. Tell them what you are planning, how you plan to do it and ask their advice on what is needed to meet code. They may not like what you are trying to do, but will probably give you the information you need to apply for a variance if necessary. Or you might get lucky and find they are interested in alternative building. Good planning up front, especially when doing something not many folks have done before, is essential to success. Good luck, Rosalinda |
| Sum total of my experience - Designed, GCed and built my own home, hybrid - stick built & modular on FPSF. 2798 ft2 2 story, propane fired condensing HWH DIY designed and installed radiant heat in GF. $71.20/ft2 completely furnished and finished, 5Star plus eStar rated and NAHB Gold certified |
Beastmaster
| 17 Feb 2011 03:28 PM |
We have been thinking about this and price is starting to be a concern once a permit and engineers are involved. We thought it might be best to do a hunting lodge which would be a 30' yurt but when i priced that out it came to be over $30,000 which is more than we would like to spend. Straw Bale is out because of the moisture unless we do some small scale testing on site over the next year or so.
Tire home would be nice and i think we will still consider it. We are also considering to build a small cabin or something cheap to live in while we build the property, so if anyone has any suggestions for this kind of cabin or home that is around 400-700 sqft that would be great.
I have seen some tire home designs where they build around an existing small home so maybe that is something to consider.
ICFHybrid
| 18 Feb 2011 12:56 PM |
We are also considering to build a small cabin or something cheap to live in while we build the property, so if anyone has any suggestions for this kind of cabin or home that is around 400-700 sqft that would be great. We used to call them "mobile homes". |
CURTIS596
cmkavala
| 27 Feb 2011 03:43 AM |
Posted By zehboss on 14 Feb 2011 07:57 AM No home should be cave like. Good zero energy design has high natural lighting, properly placed window, and no disadvantages. Only bennefits of smart design. Earthships are caves |
zehboss
| 27 Feb 2011 07:00 AM |
Have you been in or built an Earthship? Typically they have a solid wall of windows on one side. This is typically more natural light than a standard above grade home. I have built several underground homes and none of them have been cave like at all. All were lighter, and brighter than most homes. |
cmkavala
| 27 Feb 2011 07:20 AM |
zehboss;
yes I have been in an earthship, I don't care to be living in the same environment with ants. I am all for "recycling" materials into new re-usable building products. I am not in favor of re using landfill trash to live in.
zehboss
| 27 Feb 2011 10:49 AM |
I am not a big fan of Earthships. They are labor intensive, and have no straight, flat, level walls. I think there are better ways to build. But, properly executed you can deal with the insects or not have the indoor gardens. Using the tires and bottles are not a problem from a sanitary standpoint, but I am not big on the can use. Out here in the west the idea of recycling is strongly supported by clients. Recycle, reclaim, repurpose, rethink, and reuse, are all big. An Earthship is a lot to bite off for a DIYer. Well done they can be neat but, it is very easy to produce a crummy one that does not work well. Brian |
JimGagnepain
| 19 Jun 2015 01:44 PM |
We built a bermed earth home using tire bales. There are over 20,000 tires behind our home and a large retaining wall. We love it, and would never live in a conventional home again. The quality of life is better, in our opinion, predominantly due to four factors - extremely quiet, great views, no forced air or gas burning, and zero utility bills.  |
zehboss
| 19 Jun 2015 03:08 PM |
Great job on the earth ship. It is alot of manual labor but very satisfying, and a great personal accomplishment. 20,000 tires at 15 minutes of sledge hammer packing each. That is 5000 hours of tire pounding. Hope you had alot of free help for pizza and beer. Congrats Brian |
JimGagnepain
| 19 Jun 2015 03:35 PM |
Posted By zehboss on 19 Jun 2015 03:08 PM
No, that the beauty of "tire bale". There is no tire pounding. The bales went up in 2 days, using a skid steer.
zehboss
| 19 Jun 2015 04:19 PM |
Cool construction method. To bad it is not recognized by most code official, appraisers, building officials, mortgage entities, structural building engineers, insurance entities, etc. Did you build outside code area or find a PE to sing off? Did you build out of pocket or get financing? Anyway good job. Brian |
JimGagnepain
| 19 Jun 2015 09:32 PM |
Posted By zehboss on 19 Jun 2015 04:19 PM
According to the Earthship folks in Taos, NM, there are Earthships in every state in the US.
That said, permitting can definitely be a concern. I'm in El Paso County in Colorado, and they are more open to alternative building. There are quite a few Earthships and bermed homes in the area. At one point, one of the Inspectors questioned a section of our design. I mentioned another person in the county who used the same technique, stating that "You approved it then". He actually looked up that building permit, and then went on to OK mine. Most of the concerns with Regional Building Departments revolve around fire egresses (no windows in the bedrooms). They demanded that our bedrooms be on the ends, and then they considered the two exit doors the egresses.
A structural engineer did sign off on the design. This wasn't as difficult. It's fairly typical construction, once the bond beam is set over the tire bails.
We did not take out a mortgage. And financing is often an issue. I've heard some stories about people who got started, and had to halt construction because loans were not approved. People tell me that this is changing, but I have not seen this. We also had some insurers who didn't want to insure it. Actually, State Farm came out, and gave us a nice quote, after we were turned down by others over the phone.
JimGagnepain
| 19 Jun 2015 09:39 PM |
Posted By Beastmaster on 09 Feb 2011 07:35 PM
yes, we can get tires for free and we wil fill each by hand. We are going to look into getting tire bales, but i am not sure if they are free or not.
Beastmaster, Our tire bales were free from Tire Recyclers in South Denver. The state gives them $50/bale for disposing of the tires. We had to give them copies of the building permit, so that they could submit the refund request to the state. We did have to pay for shipping. Seven semi truckloads, 70 mile trip each way, and it cost about $3K.
JimGagnepain
| 19 Jun 2015 09:43 PM |
Posted By Beastmaster on 10 Feb 2011 09:54 AM
One of the main reasons i want to build with tires is because of the constant warm temp. What i want to know will a well constructed tire home be 65 degrees or around that in the winter with south facing glass walls and a U shaped shell?
Without any heating at all, as long as the doors and windows are closed, the Earthship won't drop below 58 deg F. We've seen ours drop down to 60 deg F, when we were gone a few days, and the nights were near zero.
JimGagnepain
| 19 Jun 2015 09:56 PM |
Posted By Lee Dodge on 13 Feb 2011 03:36 PM
Beastmaster-
Some friends here in Colorado built an earthship house with lots of glass on the south and then the rest built into a hillside with tires for the sides and back wall. They were thrilled to get the tires for free. They were less thrilled to pay $1 per tire to get rid of all the tires that they could not use once they found out that to make a wall, they could only use tires of fairly uniform size. The completed house is an energy monster, with one reason being that there is no insulation between the tire wall and the living space. Another reason is that they are not experienced home builders, which would have allowed them knowledge of previous failures. If they were satisfied to live at the ground water temperature of 52 F, they would be OK, but getting the house warmer takes a lot of fuel due to losses to the ground. Further, the top of the back wall is at ground level, and wintertime ground temperatures are much lower than the ground water temps. near the surface. They are now trying to sell the house.
Ground water temps. in the D.C. area are around 58 F, so plan to live at that temp., or figure out how to insulate a tire wall. Also make sure to compute overhangs on the south side to reduce heat gains during those hot, sticky summers. It would be nice to be able to dump heat in the summer into the cooler ground, but you would need to be able to switch off the heat transfer in the winter.
I would advise talking to somebody in the area that has built a successful tire-wall house, to take advantage of their learning curve.
Lee Dodge www.Residentialenergylaboratory.com in a net zero energy house
Much of what you say here is true - proper building techniques are mandatory! Watching a video of a hut earthship is not going to prepare one for the task at hand. I will comment about the tires being poor insulation - this is absolutely false. Tire bales have been show to be somewhere between an R-45 and R-60. El Paso County Building department looked it up and told me to use R-45 in my thermal envelope calculations. Rammed earth tires may even be better. Most of the designs call for 2 layers of #6 poly down the bermed side of the tire bales, which makes it even higher. If you want to finger point at any cold intrusion, look to the windows. Double or Triple pane low E works well, but this is still the intrusion area. In general, we have no problem keeping the home nice and toasty. We are usually even opening windows in the winter! We use outdoor shades in the summer, which keeps it nice an cool. You shouldn't knock the thermal mass aspects of these types of homes unless you've stayed in one over a few cold winter days. I will guarantee that you will change your opinion.
toddm
| 24 Jun 2015 09:38 AM |
Hi from a fellow with similar hopes for my high mass house near Emmitsburg. Short answer, no, high mass alone doesn't work in Md. Computer modeling predicted a range of 55 to 85 in my house without conditioning. Actual was 47-83 but both numbers come with huge asterisks in the east. With 90 percent RH, 83 feels like 95. For the second summer I had a 2 ton minisplit heat pump. With the house at 47 degrees for any period of time, you need a major source of btus to make a timely recovery. (i.e.much more than a 2T heat pump.) Passive solar works in Colo. but not in grey Md. I have a wood stove boiler plumbed to a radiant slab. Happily, I saw the problem and scaled back to highish mass: a well insulated slab on grade with AAC (low density concrete) walls. With those caveats, hvac with manual input, you can built a very green house. It gets too cold with the mini running continuously on dehumidify so we typically run it four. five hours a day. I burn about three cords of wood in the winter. My goal was a $50/mo power bill. We're running about $35. I backed into high mass. My design dictated major south facing glass which dictates mass to buffer passive solar on (rare) bright winter days. But if I were you, I'd find a barn to tear down, reassemble it as a post and beam house, insulate it with reclaimed foam board and call myself just as green as zehboss.
175 |
175 |
