Posted By Birdman on 04 Apr 2011 01:06 PM
I know the old myth is "bustd" about compressing FG batt decreasing it's R value. In fact, compressing it increases it's R value PER INCH. Is there any source for what the actuall values might be? For example, if I compress a 3 1/2" R-13 batt down to 2 1/2" what is the R value now (either as R per inch x 2.5" or a total?
Are there any tables on this?
An R13 batt in 2x3 framing comes in at R10:
http://www.owenscorning.com/aro...nChart.xlsor if you don't have a compatible spreadsheet software:
http://numsum.com/spreadsheet/show/21111The density of R19 2x6 batting is lower than R13 2x4 batting- in fact it's the same amount of material(!), so they should cost the same, RIGHT?
The higher the density, the better air-retardency it has, so it loses less R to convection withing the fiberglass at high delta-Ts. R19 batts are junk- I personally wouldn't install anything less than R21, if forced to use batts rather than blown in a 2x6 framed structure. YMMV.
