General Forum - Residential
best way to insulate unvented attic
Last Post 12 Sep 2011 11:58 AM by
. 23 Replies.
Oldest First
Most Recent First
Prev
Next
Page 2 of 2
1
2
Author
Messages
28 Jun 2011 01:14 PM
As long as the spaces on both sides of the wall are heated living space, you don't need to insulate. But it's still worth air-sealing that wall.
zygote nyc
05 Jul 2011 03:56 PM
Dana1,
yes space on both size is heated. What do you recommend best way to seal the wall if not using foam?
zygote nyc
12 Sep 2011 11:28 AM
Dana1, I found AirTight CC Closed-Cell Spray Foam Insulation ICC ESR-262 by Lapolla. It's 1.98 perm @ 1". Is this an ideal CC foam for me to put up 2" on the brick wall? Thanks, Zygote
That stuff would test out at about 1 perm at 2", which would work in all of your foam applications (even around where structural timbers penetrate the brick.)
A timely & relevant blog article on the subject of insulating solid brick walls: http://www.greenbuildingadvisor.com/blogs/dept/musings/insulating-old-brick-buildings
Page 2 of 2
1
2
Membership:
croccohvacusa
People Online:
