ductless air conditioning
Last Post 17 May 2011 11:28 PM by Chloe Taylor. 6 Replies.
jim5821User is Offline
07 May 2011 06:28 PM
does anyone have info on the best brand of ductless air conditioners?  Also does there need to be an air handler in every room of the house for whole house cooling or is there some other way to do it?
07 May 2011 07:53 PM
Are you referring to a system like the Daikin with variable flow and one compressor where refrigerant lines connect to blowers in each room.  Daikin air-to-air system can minimize the amount of ducts in a HVAC system but I think you will find that a top end geothermal system will be slightly more efficient.
acwizardUser is Offline
08 May 2011 02:44 AM
Mitsubishi, and yes you could go with a concealed airhandler and run several short duct runs to several different rooms.
ICFHybridUser is Offline
08 May 2011 11:32 AM
I think that efficiency, as always, will depend on the conditions. When a geothermal system operates, both the compressor and loop circulation have to run. Operation of a ductless mini can entail low speed operation for lower demand conditions.
In mild climates, it is worth determining if the lower upfront cost and more efficient operation of a ductless mini doesn't outweigh the benefits of ground source.
11 May 2011 08:14 PM
I have looked at geothermal systems and have ruled them out as too expensive - $60K here on Long Island. I have solar power on my house so the electric for the A/C is covered. Various geothernal quotations I have received from the local contractors all indicated I'd need about 3.5 ton of cooling for my home. I figure I'd have about 1.5 ton upstairs (smaller area) and 2 ton for the main floor. My plan was to accomplish this with a 1.5 ton ductless unit for the second floor and two 1.5 ton ductless for the main floor - all strategically placed.
I am a handy guy. But I have never charged an A/C unit before. I have access to the equipment if necessary. I understand that depending on the unit and the refirgerant line lengths, some charging of the system may be necessary. My question to those of you in the know would be is installing these units myself doable or would it just turn into a fiasco?
12 May 2011 04:11 AM
Not to take anything away from your capabilities but installing any a/c unit requires special tools, knowledge of how to use them correctly, knowledge of brazing copper, electrical controls, etc. Have been in the a/c business for 33 years now and still learning. Not to mention that you need to be certified by the EPA (section 608) and there is a huge fine if caught or reported to them.
Chloe TaylorUser is Offline
How about going with appliances of LG. They are cheap as well as durable too.....
<a href="http://www.capitalsteelbuildings.co.uk">Commercial Buildings for Sale</a>
People Online People Online: Visitors Visitors: 296 Members Members: 0 Total Total: 296
