Best way to attach wooden girders to concrete piers?
Last Post 30 May 2011 07:08 AM by siddle. 8 Replies.
danf26User is Offline
19 May 2011 10:52 AM
Hi, A simple (I presume) question here: What is the best way to attach wooden members to poured concrete piers? I know I could use a steel fasteners, called a Post Base (I think). I also know I could put a J-Bolt in the pier, put down a layer or two of roofing felt, and then bolt down a scrap of pressure treated wood, of which on top of sits my girders. Are there more options? What works best? Also, in the option you describe as working best, what are all the materials needed? Will be doing this next week, so am trying to figure out soon. Thank you all, Dan
Bob IUser is Offline
19 May 2011 07:16 PM
use the post base. bolt the PB to the pier, fasten it to the girder, done. One problem with using "scrap of PT" is that it will shrink across the grain, and/or eventually rot. (it does rot). the PB has an air space under the girder; it's pretty cheap & works well.
19 May 2011 07:30 PM
Dan;
roofing felt is all that is needed (t separate from concrete)
acwizardUser is Offline
19 May 2011 11:15 PM
Check Simpson Strong Ties www.simpsonanchors.com
Chloe TaylorUser is Offline
21 May 2011 12:23 PM
Posted By danf26 on 19 May 2011 10:52 AM
Well according to me, the best best way to goo about is using nail along with a drill machine and a hammer or going with the option of using glue.....
<a href="http://www.capitalsteelbuildings.co.uk">Commercial Buildings for Sale</a>
27 May 2011 09:11 PM
SO, with the Simpson Strong Ties, where two girders are meeting over the same pier, should I have two strong ties, each connected to the pier with separate bolts, to catch each one individually? Or do I have the butt ends meet in the middle of one of the ties?
28 May 2011 12:32 AM
You can use one if it is applicable for the load and size of framing members.
28 May 2011 03:08 AM
Posted By acwizard on 28 May 2011 12:32 AM
Seems to be a nice idea for sure...... :)
siddleUser is Offline
The post base, poured in place, is indeed the best way to go.
Absolute Steel— Steel building and carport kits with nationwide jobsite delivery. Easy DIY—America’s easiest to install building system. Watch the video & see for yourself.
People Online People Online: Visitors Visitors: 279 Members Members: 0 Total Total: 279
