Pool Construction
Last Post 22 Jul 2011 04:05 AM by hassan. 3 Replies.
GreenMonsterUser is Offline
18 Jul 2011 10:00 PM
What are some ways that a traditional pool can be modified to save energy. Besides adding a solar cover to heat the water are there any easy fixes to save money on a pool? Since  most water return lines are located near the top of the pool is there something that can be done here to create energy from that water flow source.
<a href="http://www.familyleisure.com/Above-Ground-Swimming-Pools">Above Ground Pools</a>
acwizardUser is Offline
19 Jul 2011 03:42 AM
Energy savings are usually possible by studying the performance curve of the pool pump. The pump must be large enough to overcome the feet of head and still deliver the flowrate necessary for proper filtration. Reducing pump run time to achieve a clean pool i s the best way to reduce energy consumption .
19 Jul 2011 09:24 AM
Insulate the walls, perhaps using ICFs. IMO, ideal would be a clear cover during the day and a thicker insulating cover at night.
hassanUser is Offline
Use the latest marble titles for the pool must be follow the location then you make a good environment of your house.
[url=http://www.soldsameday.com/blog/tag/buy-my-home-now/]buy my house now[]
People Online People Online: Visitors Visitors: 231 Members Members: 0 Total Total: 231
