There are a few underlays out there than will make a bit of difference to the noise. Make sure that the cavity in the walls is insulated fully , as this is where most of the noise will travel from. I spent a lot of money on high density underlay because I could here the TV from downstairs this is a very expensive type of soundproofing
building materials. But the sound was only slightly dampened. I then realised that the noise was coming up through the cavity. So check that you have it.
