Noise Reduction
Last Post 12 Sep 2011 11:41 AM by whg. 9 Replies.
whgUser is Offline
30 Aug 2011 02:11 PM
Residential condo unit over top of a bar and kitchen.  Floor assembly from bottom up is sheetrock ceiling finish, 2x10 floor joist.  Fiberglass batt insulation in between joist bays.  Two layers of 5/8" CDX plywood (felt paper in between layers).  There is some noise coming up, mostly from the bar when it is busy.  This is more of a restaurant with a bar that gets busy.  Its not a night club that is hosting Metallica on a regular voices.  Airborne noise is mostly loud voices and laughing that increases after that fourth or fifth beer.
I have talked to some folks, done some reading online, have heard some different options.......anybody have an suggestions or expericences with underlayements or barriers that may be insalled under a carpet.  The space will most likely be finished with carpet and some limted ceramic tile.
Thanks for any feedback.
Garth SprouleUser is Offline
01 Sep 2011 07:31 PM
Talk to a professional sound control company...maybe these guys to start with...
http://www.soundproofingcompany.com/company/
03 Sep 2011 06:27 AM
whg; I have used cork under ceramic tile and can be used under carpet as well. http://www.quietcork.com/ It gets glued to the sub floor, I would also try to get to any wall / ceiling penerations and plug those up
Jerry D. Coombs, PEUser is Offline
04 Sep 2011 02:08 PM
Looks like the site Garth suggested is a pretty good one. For many of their suggestions, you have to be REAL searious about wanting the sound out. One good rule of thumb: Higher frequencies are filtered out with insulation (of many types.) For low frequency, you need mass. Concrete being the most readily available.
<br>You can have with quality; You can have it fast; You can have it cheap.
Pick any two.
hassanUser is Offline
06 Sep 2011 12:43 AM
Before replay visit some sites then you idea how much perfect installation for your home noise if you visit Google search engine then you get better way for the home noise.
[url=http://www.soldsameday.com/blog/tag/buy-my-home-now/]buy my house now[]
jumpingspidermediaUser is Offline
08 Sep 2011 12:14 AM
I think I would have to agree on Garth and second Jerry's opinion. Although,you may find others when you search you'll have to make sure they are reliable!
<a href="http://www.londonccc.co.uk/">Carbon credits</a> | <a href="http://www.londonccc.co.uk/content/self-invested-personal-pension">Carbon investment</a> | <a href="http://www.londonccc.co.uk/content/what-are-carbon-credits">Carbon trader</a>
builder66User is Offline
08 Sep 2011 03:32 AM
There are a few underlays out there than will make a bit of difference to the noise. Make sure that the cavity in the walls is insulated fully , as this is where most of the noise will travel from. I spent a lot of money on high density underlay because I could here the TV from downstairs this is a very expensive type of soundproofing building materials. But the sound was only slightly dampened. I then realised that the noise was coming up through the cavity. So check that you have it.
acwizardUser is Offline
08 Sep 2011 04:57 AM
Your best bet will be a lightweight concrete with carpet installed over the top.
blossom2347User is Offline
12 Sep 2011 01:44 AM
SPF also work for that. If for making it noise proof.
<a href="http://www.oceansevenroofing.com/Services/Insulation/Insulation.html">SPF Roofing</a>
whgUser is Offline
Thanks for the help. I have done some research and spoken to the soundproofingcompany several times. Their first piece of advice was to take an inexpensive stethascope and put it on the various construction elements and see where the noise is coming from. I have some hi-density batts I just installed and some previously existing fiberglass still installed. Was interesting to see the difference in sound transmission through the two. Long story short, I am going to use a combinaiton of double studwalls, offset studs and green glue everywhere possible. It does cost money but the space is relatively small and its a lot easier to do it now then 6 months down the road when the space is all built out.
People Online People Online: Visitors Visitors: 179 Members Members: 0 Total Total: 179
