Hi.
I recently posted a question concerning the installation of 1" sheets of paper-faced polyiso applied directly to my concrete block basement walls. That thread may be found here:
http://www.greenbuildingtalk.com/Fo...fault.aspxBecause the material was priced so well, I went ahead and bought 48 sheets of the insulation. Unfortunately, my subsequent research on polyiso has revealed that it is a poor solution for below grade applications. As such, I am stuck with the insulation (can't return it because it was factory direct). I am now trying to determine if I can make use of it in some other way. Which leads me to the following proposition.
I have previously described the construction of my 1968 house on this site. Briefly, the attic consists of site-built 2x4 trusses placed 24" apart. There is approximately 4" of blown fiberglass insulation sitting on top of the drywall ceiling. I had intended on air sealing the attic floor and blowing an additional 12" of cellulose over top of the fiberglass, but Dana1 advised against that due to structural concerns. He advised that I modify the site-built trusses to create Larsen trusses, spray one inch of closed cell foam on the roof deck, and then wet-blow in blanket cellulose. I really like this idea and have started the modification process.
I am now approaching a point in which nearly all of the trusses have been converted into Larsen trusses and will need to apply the spray foam. I am wondering if I could actually cut down the 1" polyiso into 24"X96" sections, place that between the rafters, and then apply a thin layer of closed cell foam over that to acquire a good air seal. I could then install the mesh fabric and blow in the cellulose.
I realize that this approach may be unconventional. My research indicates that polyiso is typically used on the exterior of the roof deck, however, it seems like it will conceptually accomplish the same goal if it was applied on the interior surface. Please correct me if I am wrong.
If that won't work, I have 48 sheets of 1" paper-faced polyiso that I will let go at a slightly discounted price (less than I paid) in the upstate SC.
