Suggestions for crawlspace insulation w/radiant
Last Post 17 Nov 2011 09:33 PM by rbisys1. 6 Replies.
jwUser is Offline
16 Nov 2011 08:07 PM
I am looking for a plan to insulate an unvented crawlspace with newly installed radiant heat with transfer plates.  I am in New Jersey.  The crawlspace has a dirt floor and needs a radon barrier.  It has 10 inch joists w lots of plumbing/steam/gas/electrical and one small section of 6 inch mortar under bath tile.  My original plan was to net it with a perforated foam/ radiant barrier, blow cellulose, and seal the sills.  Worried about thermal bridge.
jwUser is Offline
16 Nov 2011 08:10 PM
The steam/gas/electrical are all just piping and conduit.  No burners or meters.
16 Nov 2011 09:50 PM
IMO (based on seeing lots of black mold), either vent it to the inside or the outside. Of course insulate the crawlspace floor and walls in the former case.
WindowsonWashingtonUser is Offline
16 Nov 2011 10:08 PM
Definitely needs a really good vapor barrier across the floor. Are you going to covert it to a conditioned crawl?
The steam piping, barring any leaks, should help dry out the space.
The difference is clear
jwUser is Offline
16 Nov 2011 10:13 PM
I hadn't thought about venting directly to the outside. Maybe the ticket. Skip the ground retarder and PVC pipe. Now, what ceiling and sill insulation would you reccomend?  There is also a concrete block interior wall leading to finished basement/laundry/boiler.  There is some fiberglass on the interior but it would benefit with something on the crawlspace side( outside the envelope).  Does it matter?  Is moisture a non issue no this wall?
jwUser is Offline
16 Nov 2011 10:15 PM
No conversion in the immediate future but always a possibility.
rbisys1User is Offline
Greetings,
I came up with a RB sys several years ago for your type of installation. It easily out performs foam.
A sheet of 4-6 mil plastic attached to the side of the top plate and allowed to hang down and across the floor/dirt. Cover remainder of floor with 4-6 mil plastic. overlapping at least 6".
For radon you might want to 1st lay min 2' perforated pvc pipes and vent both ends thru the sides of the house.
Attach a single layer of 48" foil insul to the side of the top plate over the plastic and let drape.
If you have rad. heat a layer a foil over the plastic on floor.
Install RB sheet between joists at rim.
Be sure to SEAL ALL exterior leaks.
Crawl space temp will be about 2 degs cooler than house temp.
People Online People Online: Visitors Visitors: 443 Members Members: 0 Total Total: 443
